Auris D4d Cigaret Lighter Fuse Location
Rall
Hi I have a 2009 auris D4D desiel 2 litre and I can not location the fuse I have look at the fuse box in the engine compartment its not there, removed the glove box, I would have thought if is a 15Amp fuse, I would be grateful for any help
Should be in a fuse box underneath the dashboard on the passenger side (not inside the glovebox) - fuse no 8 (15aml).
On LHD
Behind the glove box
Remove the kick plate under the dash then you will see a small whit panel romove that it is in there ... There are two cigarette lighter fuses ... It will be one of these
On RHD romove the panel that has the wing mirror adjustment switch the whole panel unclips and they are behind there
