Yaris Wheel Arch Protective Film
rushy45
Hi, I have a 2012 5 door yaris, on the offside the rear clear plastic arch protector film has a small hole in it, only couple of mm round, its right on the bend and really catches the eye, I tried putting touch up paint in it to level it up but does not work.. looks worse, I think the only cure would be to remove the clear film and replace it, anyone know if and where you can buy these, also is it likely to damage the paintwork removing it. Thanks
Probably something like 3M Ventureshield. Suppose with careful application of heat (hairdryer, etc) one could ease the film off. Best place for a precut replacement would be your Toyota dealer, or you could send Parts King a personal message, giving your car's details, and specifying what you want (would probably get some discount).
