Auris Coolant
majeeka1976
Hi
Quick question what's the correct coolant type for a Toyota Auris 2008 Uk model ? Is there only one type of pink coolant?
Damian
As far as I'm aware, there are two types of Toyota coolant generally available in the UK - Toyota Super Long Life Coolant (pink) and Toyota Long Life Coolant (red). You will need the Toyota Super Long Life Coolant.
In the Auris coolant should first be changed at 10 years/100,000 miles (whichever occurs first), and then at 5 year/50,000 mile intervals
I'll order some super long life if I need to top up
Thanks for the advice
  • 4 years later...
What is the coolant capacity  for a Toyota Auris 16 cc 2009
Capacity is 5.5 L, if you have 1ZR-FE engine, or 5.6 L for 1ZR-FAE engine
