Avensis 2.2 Error Code P0032(engine, Vsc And Trc)
J.R.
Hello all...
Anyone have experience with the error code:
::P0032 - Oxygen Sensor Heater Control Circuit High Bank 1 Sensor 1 ::
This error comes and go on my Avensis T25 2.2 D-cat, sometimes i dont see the failure for many days and other days it happens several times a day.
Sometimes the error goes away by itself, it lights up with engine warning, VSC and TRC on my way from work, 2 hours later i start the car and there is no error. Other times i remove it right away with my error code reader and it doesn't come back again that day... :/
No loss of power, the car is running fine!
I changed the bank 1 sensor 1 about 1 1/2 month ago and the error didn't show up for 3 weeks, then suddenly it showed up again, what the hell can that be, cant believe that the new sensor went bad also and if it was weak in the heater circuit, why only sometimes ???
Does anyone tried something similar and want to share there knowledge ??
Regards
Jesper
