Help! 2005 3 Door Corolla Water Leak Where Spare Tyre Is!
need help i bought a car recently and have noticed quite a severe amount of water in the boot well where the spare wheel is and is starting to make the boot rust! any ideas how to find the leak,fix the problem and has anyone here experienced this? the car is immaculate for being ten years old and having only one owner but down side is the leak! could someone enlighten me as soon as possible.
thanks
Could be from many areas around the boot.
The rear light clusters could be a bit loose /seal gone and letting water in there.
Same with the hatch , any damage to the seal of the hatch or the hatch glass seal ?
Getting in from around the wiper arm.
A hole / damage to the underside ?
Try putting some sheets of newpaper all over the boot area and then spray the car with a hose pipe for a few minutes, let the excess drain off then open the hatch and you will hopefully see some wet areas where its come in.
Put some new
As oldcodger said water can come in from the least expected areas. When you do the water hose test, make sure you spray from many different angles. Also from below, which may seem a little counter intuitive.
Sent from my iPad using Toyota OC
That's great I will try and be more patient this time doing the water if it's the sponge seal on the rear lamp where can I get a new seal?
Like most of those seals, probably only your local Toyota dealer, not parts anyone would find worthwhile copying.
If it's anything like the leaky rear lights on the Auris you may find that a tube of clear bathroom silicone sealant does as good a job (or better) than the official part from Toyota!
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
