Green Engine Coolant Light
Prophetto
Hi everyone ! I have bought Yaris 2012 couple of days ago and to day i have noticed that when i start up the engine then green engine coolant light comes on and after some time light goes off . Just wanted to ask what does it mean and is it normal ? Thanks in advance .
Hello Maris - welcome to Toyota Owners Club.
Presume this is the low engine coolant temperature light which has a 'C' and a 'thermometer/water' symbol'
You haven't said whether your car is petrol, diesel or hybrid. Have a look at pages 281-283 of the Owners Manual
Think these would come on as a check that the systems are OK, and go out after a few seconds. If it stays on or doesn't come on at all, that is the time to get the car checked.
This sounds normal to me - on my 2009 Verso (2.0 D4D) there is a blue indicator that comes on when you first start the engine (if the engine is cold) and then goes after after a few minutes once the engine (and coolant ) has warmed up. My 1999 Yaris 1.0 Petrol has a similar indicator.
It's also a blue light in my 2015 Yaris. Light goes off when coolant temperature is in regular operation range.
