Hi all.
Got my engine warning light on the other day, so got my step-dads code reader on there and it came up with a P0411 (secondary air injection system incorrect flow detected).
Have rung my garage and they said that they would still have to use theirs to confirm code (obviously so they could get the £30 out of me - typical!).
Anyway just thought i'd ask if you had any suggestions before i go so i know they aren't ripping me off with their conclusions..
Got a 52 plate t sport which i have been saying to the garage (same one) for 6 months or so isn't pulling well - seems very hesitant and pulls back whilst on the move. typically they told me to use my right foot more and laughed then said there was nothing wrong with the car and that it was me...
This is all fine except when you're talking about a complete petrol head who has track day'd more than they've had cooked dinners... I CAN DRIVE A CAR!
Pre - said thanks for your help....
Secondary Air Injection System Incorrect Flow Detected
OBD II Fault Code
OBD II P0411
Fault Code Definition
Secondary Air Injection Incorrect Flow Detected
What does this Mean?
The Secondary Air System pumps outside fresh air into the Exhaust System during cold engine start up. This additional air helps burn up the very rich exhaust emissions that are produced when the engine is warming up. The Secondary Air System typically has an Air Pump, some tubes or plumbing to route the air and Air Management Valve(s) to control the air flow.
Symptoms
Check Engine Light will illuminate
In many cases, no abnormal symptoms may be noticed
In some cases, the engine may hesitate on acceleration
Common Problems That Trigger the P0411 Code
Defective Air Management Valve(s)
Faulty Air Pump or Air Pump Relay
Faulty air control solenoids or vacuum lines
System may be restricted or plugged with carbon
Common Misdiagnoses
Air Managment Valve(s) functions, but is slightly restricted
Air Pump is replaced when the relay is the problem
Parts are replaced when the the system is restricted or plugged with carbon
Notes
Many vehicles set a code P0411 due to restricted Secondary Air Management Valves
Study the Diagnostic Theory section below to learn about the scan tool data that indicates defective Air Management Valves and the advised replacement procedure
P0411 Diagnostic theory for Shops and Technicians
When a code P0411 is set, the PCM is not seeing the front oxygen sensor voltage drop sufficiently when the Air Pump is supposed to be adding outside air in to the exhaust system to burn off the excessive HCs and CO that are created during the cold start of an engine. One should test the system with a data streaming scan tool, during a stone cold start up of the engine. Some scan tools provide the Technician methods to test the Secondary Air System or SAS when the vehicle is already warmed up, but this feature is not present on all scan tools.
Cold start the vehicle and watch the front oxygen sensor(s) on the scan tool data stream. After about 5-10 seconds, you should hear the secondary air pump start, it actually sounds like a vacuum cleaner running under the hood. Just as the Air Pump kicks in, the front oxygen sensor(s) voltage should go to less than .125 volts ( 125 millivolts ). If this does not happen, then you have verified a fault condition in the SAS or Secondary Air System.
If you do not hear the Air Pump Motor start, then check the SAS Air Pump and relay.
If you hear the motor, inspect the components that control the Air delivery such as the Air Management Valve Solenoid, the Air Management Valve and the rubber hoses, metal piping and passages.
On V6 or V8 vehicles, if BOTH front oxygen sensors do not drop to below .125 volts or ( 125 millivolts ) then blow into the Air Management Valve(s). The valve or valves should flow very evenly.
NOTE: you must replace the check valves as a set or the code will keep re-setting, because the PCM needs to see an EVEN drop of the front oxygen sensor voltage.
