Alarm?
Tod4
I have a 2007 XTR D-4-D. In the hand book it says it you want to deactivate the movement alarm you should press the small button up by the mirror after you take the key out. To test the movement alarm leave the sunroof open and wave your hand about inside. I didn't press the button and locked the car. I then waved around inside like a fool and nothing happened. Am I setting the alarm correctly (I just press the key fob once) or is the alarm broken?
