Avensis 53 2l D4d Problem
leeshade
I have a 53 plate avensis 2L d4d with 180K on the clock.
Wondered if anyone can help me with an intermittent problem i get.
It happens when I turn (usually at roundabouts) and shift into a lower gear, it seems there is some grinding/mechanical action taking place under the car, possibly around where the driver sits. Its not gears grinding and is most similar to when the traction control comes on. It doesnt happen everytime and only at higher speeds. I dont notice any traction indicator on dash - which is working.
Also does anyone know what/where the clutch slave pipe is - and whether it is a simple job to replace
download the attachment it will show you what you need to know.
Avensis clutch.pdf
Have a look at the wheel bearings,jack it up grasp the wheel at 12 oclock and 6 oclock and rock, see if there's any knocking or play.cpold also be CV joint or bottom ball joint.:D
