Hello,
Great topic by the way.
I have problem after the firmware update.
As starting point it was 0810 version in my Aygo 2015.
I've updated to 0820 successfully but my rear camera stopped working. Now when I put rear gear, blank screen appears. Everything else works fine.
I have made 840 and 850 update with success but rear camera still not working.
Anyone had such problem. Anyone can help me with that?
  • 1 year later...
On 4/19/2020 at 6:55 PM, Devon Aygo said:
- If current version shows :"0840","0830","0820","0810" --> proceed STEP VIII
- If current version shows "0705", please apply TSB no. BE-0015T-0217
Good day to all!
I upgraded from 0705 to 0850
And then I found this instruction. What can be wrong for me?
Two photos before and after the update.
Here is a photo with an attempt to flash from the service menu
Is it possible to downgrade to version 0705 and update correctly?
  • 7 months later...
On 4/19/2020 at 4:55 PM, Devon Aygo said:
Version 0850 HERE please follow the steps below paying special attention to step VII:
Table 1. Follow below steps to perform the actual software-update :
1. Prepare a USB-stick to update the X-Touch Display-unit to software-version 0850.
  1. PLEASE TAKE A NEW, EMPTY OR FORMATTED USB-STICK WHICH MEETS FOLLOWING MINIMUM REQUIREMENTS :
    - the used USB-stick must not have a HUB-function (it should not contain a card slot or another USB-device insertion slot).
    - the used USB-stick should not have a security function (encryption, ...).
    - used file system on the USB-stick should be FAT32.
    - USB-stick capacity/size should be more than 1GB.
    - used USB-stick should not carry write-protection.
    - USB-standard = USB 2.0
    - the USB-stick preferably has a LED-indicator lamp to see "access" status.
  2. Important
    If the USB-stick already contains previous data or files, please format the USB-stick using FAT32 file system.
  3. DOWNLOAD THE "0850" SOFTWARE VERSION UPDATE FILE (.KWI-FILE) ONTO YOUR LOCAL PC HARD-DRIVE
  4. COPY THE DOWNLOADED .KWI-FILE FROM YOUR LOCAL PC HARD-DRIVE LOCATION TO THE EMPTIED USB)STICK.
    Important
    i. Don't save other files onto the USB-stick together with the .kwi-file.
    ii. Do not change or rename the .kwi-file.
    iii. Don't put the .kwi-file inside a folder on the USB-stick.
  5. PLEASE LABEL AND NAME THE USB-STICK FOR FURTHER LATER USAGE. E.G. "AYGO X-TOUCH 0850"
At this point, the USB-stick is ready to proceed with the actual software reprogramming --> see "2. Update the X-Touch Display-unit to software-version 0850"
STEP no.
ACTION
DETAIL
I
switch vehicle ACC or I/G ON (depending on vehicle status or location)
II
(If "Menu” screen is not displayed, press lower knob to access "Menu” screen.)
Press "SETUP" to enter “Setup” screen.
III
Press "General" icon
IV
Press "Down" arrow button
V
Press "Software update"
VI
Press "Update"
VII
VIII
Insert the prepared USB flash drive in the vehicle's USB - connection port.
--> "New software was found." pop-up will be displayed
IX
Check if the correct software-version "0850" is displayed under “New”.
If so, push “Update software”-button to continue.
X
Press “Yes” on the Software-update confirmation screen.
XI
Wait for the software-update to finish completely.
(This should only take a few minutes)
Important
・Do NOT turn OFF the engine or ACC before the software-update process has completely finished.
・Do NOT remove the USB-stick from the vehicle USB port
XII
When the software-update has finished completely, the "Ready with update" screen is shown.
XIII
- Switch ACC or I/G OFF
- Remove USB-stick safely from vehicle USB port
(Switch ACC or I/G back ON)
Where are you getting these updates from?? I can't find them anywhere
The toyota tech portal - 0850 is for the xtouch there is a more up-to-date thread than this
  • 1 year later...
I am on version 0705, does anyone know how to upgrade to 0850?
I understand that I need to upgrade to 0810 first, but where can I find the upgrade file?
The main, more up to date thread is here, i will drop you a PM
  • 2 months later...
Good evening guys,
I found the video below:
#131 Android Auto or Apple CarPlay upgrade Peugot 108, Toyota Aygo or Citroën C1
I wanted to know if it is possible to exchange the original multimedia system for the new multimedia system (node 86140-YV020- with DAB+, Android Auto and Apple CarPlay) in the Aygo X 2014?
Compliments,
CYK
See:
FROSTYBALLS thanks for information.
