2006 Face Lift Steering Wheel
frankie406
Hi I'm looking to retrofit cruise control on a 2006 pre-face lift avensis and have found a cheapish 2006 face lift steering wheel with cruise fitted will this fit the 06 pre face lift model?
I used only the cruse control knob from the facelift on my 2004 Avensis. Just had to drill a hole on the side of the steering wheel and add one cable to the plug. Don't know about the whole steering wheel, but if you buy it and it does not fit, you could do what I did.
True.i will give it a try.thanks 👍
