2.5 Diesel Hilux .problems With Tickover And Lack Of Power.
cundlegreen
Hi, I've just found this group, so I'm hoping some of you experts will be able to help. I've owned my first toyota for nearly a year now, no problems running at all. Its 1998, and had 145,000 miles on the clock. I suddenly had a problem with it this week after driving approx 25 miles in hot weather, it kept cutting out when starting, unless I revved it hard. When ticking over, it was very lumpy, and lots of black smoke. I got it home, and the next day on a short run it was fine. On advice from a toyota owner, I changed the fuel filter. When I started it up, it ticked over really sweet, but as soon as I went to move it , the engine stopped under load. I looked up on the internet that it might be the EGR valve, so had that off this morning. Under advice from diesco I put a a solid gasket in the short manifold. It is every bit as bad, wouldn't start and run unless under heavy throttle. The minute I took off the pressure, the engine died again. I though it must be injectors, diesco say not. What next? Should I be looking at the injector pump?
Hi, Welcome to the club... Enjoy :driving:
