Kn Air Filter On T180
actechy14
Hi gents. I put a k&n air filter In my t180. now on boost at around 2500rpm, the air blows off. In your opinion, could this be caused the increase In airflow from the filter? I'm hoping I don't have a boost leak from a hose..
As in a panel filter or cone as I have seen a few on here done cone conversion
Just the panel filter, sorry should have mentioned that.
Hi Jordan,
check the large hose onto the top of the turbo at the very back of the engine. I changed mine recently and had the same problem, turned
out the hose was loose and on high boost it blew off. Make sure the hose is properly located and the clip is tight.
