Twin Turbo Initial Syncronisation V8 200 Series
vdj200rtoyota
has any one out there had to adjust mechanically the stops on the variable vane turbos ?
Just recently fully rebuilt the 1vdftv v8 ,including new turbos (twin)
they are a vari vane stepper motor controlled with hall effect positioning feedback sensors ,that feed back to the stepper drivers
the is no slotted area to adjust the sensor , and usually electronic engine self calibrate, the only adjustment is on the vane stops on the turbo housing (extremely difficult to get too , and adjust both side turbos the same )
the car throws codes control boost sensor A ,...or B low or High
have checked all harness for continuity ,voltage ,checked and swapped over the driver boards , removed and replugged sensor and manually held in position ...and cleared faults all good , however refitting sensor to turbos puts the sensors in the hi or low position ......
the only logical way it to adjust or calibrate
anyone have a procedure for this ..........I know the local turbo guys don't , and just read a forum from a Toyota dealer asking the same question .....
