Prop Shaft Centre Bearing Replacement
JesusJohnson
Just had the RAV in for mot and the prop centre bearing is shot, totally, £1100 for a new prop, can the centre bearing be bought and fitted separate as the prop is in good condition, found one on eBay for £50 but Toyota is saying they don't known if it can be changed without ordering a complete new prop?
Phone a prop shaft repair place and get a quote
It's a pity you couldn't just remove the rear propshaft and run it as a 2 wheel drive. Save £1100 and a couple of mpg.
