My Avensis Won't Start On First Turn
vespakev
My Vermont 1.8vvt won't start on first turn but will start on third or fourth try
I have replaced plugs filters but to no help
Any ideas
Fuel?
When you turn the key the first time then switch off, do you hear the fuel pump run?
When the car starts, does the the engine start clean or needs some throttle? Normal the engine should start without touching the throttle.
Does the engine sound like it is missing initially?
Check all vacuum pipes, and the inlet pipe between the air filter and throttle body.
Do you mean that the starter motor does not respond to the turn of the key? If so then the problem will be a faulty ignition switch.
I here the pump running but on starting it does not start but after another two tries it starts sounds like not getting fuel
Yes need throttle and sounds like it missing but drives fine
Starter motor is fine
