Ajusting Handbrake On A 53 Plate Avensis D4d Estate
jem555
how do you ajust the hand brake any body no
If it's a T25 there's shoes inside small drums built into the rear discs. They adjust like old school shoes ie turn the adjuster.
also how do you ajust the hand brake cable
If it's a T3s then it's a T25 shape, I'd adjust the shoes first. IIRC you can do it through the hole of a removed wheel nut, no need to take wheel off.
will that take up the slack on the cable
No but it'll take up slack at the drums. If the shoes are properly adjusted and the handbrake is still rubbish then look at the cable.
how do you ajust the cables
I never knew this, Im going to give it a try
