Hi Any Advice please . My temp gauge is not working . Changed the Sensor today . but still not working :'( .
Corrolla 1.8 vvt-li .
Moved to the Corolla club
Thanks Frosty .
Assume you used a new sensor ? ( a little at £7 new at ECP )
Looking at my standard 1.4/1.6 diagrams after the sensor it all goes into the combination meter / dashboard and no clues of how to test things after the sensor.
The current edition of Car Mechanics magazine has a 6 page spread on repairing Instrument Clusters, might be worth a look and contacting some of the repairers mentioned.
Thanks Oldcodger. Yes put in a new Sensor. So guessing its something wrong with the dash water sensor clock .
Ecu failure or wiring issue
Surely a ECU Failure would give more problems than a water gauge not working ?? . wiring could be . . But thank steven
Could be as simple as the thermostat stuck wide open and the car not able to get warm, worth a look
thanks Parts King . Put two water sensors on . still same . engine blowers hot and cold air And the engine fan kicks in and goes off . So iv not got a clue . guessing its something to do with the dash board clock (water temp gauge)
Put a thermostat in it then, not the sender switch ;)
