Throttle Problem
Mechanic1
Hello everyone! I own a toyota hilux diesel 1994, japanese import 3.0 engine 1KZ. The problem is the car stops running after 1km of drive and after that it doesn't accelerate. It stats fine but after the throttle gives up there is smoke. I've checked everything but can't figure out the problem. I'm guessing the diesel pump is causing the problem but not sure. I've checked all the electricals and everything seems fine. The car was running fine before and the problem only arised now. Any help wold be appreciated. Thanks.
