Handbrake Cable Adjustment?
jazzyman
My handbrake needs to be adjusted because of excessive travel and my MOT is due next week. What is the correct way to adjust the cable?
If it's the same as an Avensis of the same age then there are handbrake shoes inside small drums built into the rear discs. They can be adjusted like any old-school drum brakes ie by turning the adjuster. Maybe worth checking out whether your Auris has them?
Edit... I don't think excess travel in a handbrake causes an MOT fail these days, AFAIK it's how good it works, not the number of clicks like in years gone by.
