Just Brought A 2007 Auris 1.6, Alarm Problem
tony2311
We seems to have a problem with the Alarm.
Some times when you unlock and open the door, the alarm goes off.
Press unlock again then the alarm stops for a second or so and go off again.
The only way to stop it is to close and lock doors.
This has happen a few times already today.
any idea on how to go about finding the fault?
Remove the existing alarm system and chuck it off, then fit a brand new one, regardless is Toyota genuine or aftermarket...
Usually, an alarm system lifetime is 3...5 years.
  • 4 weeks later...
It must be a CAN-BUS alarm system; first you have to identify the module (where is situated inside the car) and unplug it, then central locking will work normally.
It can be anywhere behind the dash, because it needs a +12 V, a ground and two wires from CAN-BUS. You'd better ask an electrician from Toyota.
