Yaris 01 1.3 Lazy Starter?
greg1234
Hi all,
Yaris 1.3 2001, owned for a year, 3 times within that year when Igo to start the car the starter motor sounds more high pitch and the engine turns over slowly,batt fine, thinking lazy starter,are these a common problem?
No
Possible causes:
weak Battery
alternator not charging properly.
Earth connections from Battery corroded. (clean)
Battery connections loose.(tighten)
Try last two first.
