Hello I'm wondering if any one can help me I'm wanting to purchase a Toyota Corolla 2.0 D-4d which has done 64k with full service history. I just wanted to know if this was too cheap. It's from a dealer any help would be really helpful
you have not said how much and not posted any links?
Its a good price, bear in mind its due a timing belt change should be done every 60,000. I would take it for a good test drive preferably where you can use 5th gear, make sure it does not pop out and make sure there is no power loss from the car.
the clutch should bite nice and low, there should be no noise coming from the flywheel when in neutral.
apart from this it should be a good old workhorse at 65k it has many miles left in her.
Thank you so much that is really helpful. How much would a timing belt change be.
Thank you very much
