Sticky Clutch
davidfbmw
hi all
I've recently bought a 10 plate yaris d4d, all ok at first but daughter and wife have both said that the clutch sticks half way up/down and can't get next gear unless you press again, then alls fine again.
anybody had same problem or ideas of where to look
TIA
dave
The clutch may need bleeding.. there is a bleed valve at the slave cylinder. It uses the same fluid reservoir as the brakes.
Hopefully easy fix then, was going to get brake fluid changed anyhow so hopefully solve both in one go
