Abs, Trc Off & Vsc Lights On
astoy
All,
I just had Abs, Trc Off & Vsc Lights turn on in my Avensis D4D.
There are other threads which discuss this, but most talk about expensive replacement parts.
The lights came on because both rear break lights stopped working (one was intermittent, the other seems to be blown).
This causes the three dash lights to go on.
After fixing just one of the lights the dash board lights can be reset. The reset process is to turn the dash on (don't start the engine) then press the brake pedal rapidly 8 times within 5 seconds.
This then checks that at least one brake light works and turns the VSC, ABS and TRC lights out.
There may be other errors that set these lights off, but this is the one on mine.
Certainly better than paying £200+ for a repair job that might not be needed.
Regards,
Andy.
Source:
http://www.toyotaownersclub.com/forums/topic/144229-abs-trc-off-vsc-lights-on/
