Prius Convert Into T-sprit
sagarka
hello
i have a toyota prius 2007 without navigation and bluetooth systems
i badly want to install both of them please tel me which parts i need and where i can buy that parts
i have some knowledge about electronic and micro electronic.
is it possible or not i wil be very thanks ful if some body know about this and give some useful link because in my country (germany) its little bit of diff to find such parts i wil go to uk next week and i can find all the parts easl.
thanks in advanced
Might be helpful for you to say which media system you currently have, and possibly then members may be able to respond.
how i can check that which media system is this.
thanks for yours reply
http://priuschat.com/threads/gen5-nav-plug-and-play-upgrade.94810/
it's a start
The nav drive looks to be about £150 used
mfd about £200 if you can find one - eBay looks to be mainly US units
the amp £50-100
gps antenna £50 if you can find one
then harnesses which may not be easily available outside of main dealer.
So £500 already and still lots of bits to get
You could do with finding a breaker who will take everything out for you, job lot, including wiring.
Why would anyone spend all that money to end up with a built-in sat-nav with an unintuitive UI and old routing algorithm?
I reckon the routing algorithm in my 2008 Toyota is the technological equivalent of Microsoft's (NextBase) Autoroute PC application from the early 90s, which is pretty crappy compared with the portable units like Garmin, or Google maps.
