Remove Door Mirror Class
mr ben
Hi Guys
I need to remove the mirror class, have looked at the manual but still not sure, anyone done this
please advice
Mr B
Hi Robert
If you use the motors to tip the top of the mirror glass forward you can get your fingers over the edge of the mirror frame and give it a tug and it will un-clip. If you have heated mirrors be careful and pull the heaters spade connectors off
David
Hi David
How are you?. Yes I ask at local garage today and they said the same as you, just wanted to confirm how it was done just in case I damaged it .
I am doing other things to my car will send you pic, Your car going ok
Robert
