Avensis Mk2 2004 Air Bag Light B1153 Seat Position Sensor
avensisd4d786
I have this air bag light come on now and again, but it has been getting more regular these last few days,
can someone advise which wire it is and where it could be? Im sure its drivers side.
is it just a case of unplugging and cleaning the sensor.
Might be associated with the airbag squib clockspring. google it
Its because your wiring loom is being snagged under the seat.
Being a taxi I think you have matt / carpet protectors.
What you need to do is..
1 disconnect the Battery
2 let it drain about 1 or 2 hours.
Undoo the seat bolts tip the seat over, unplug the spring back connector, and reconnect..
Get a little tip tie and tie the wiring loom to the underside of the seat.
1 disconnect the battery
good point I will give this ago, thanks.... if it was the squib wouldn't it be on all the time
