Hi guys,
Could someone tell me the engine rpm values of a Corolla Verso D-CAT (177 hp) in sixth gear at the following speeds?
130 kph (~80 mph)*
140 kph (~87 mph)*
150 kph (~93 mph)*
I need a replacement gearbox for my 2.2 Auris, and I've only found used CVerso ones. I'd like to see, if the ratios are similar to the Auris.
I used to have a 2.2 D-4D Avensis (136 hp) transmission installed for a few weeks. It worked and fit mechanically, but the gear ratios were too short for the 177 hp engine. I don't want to make the same mistake again.
Thanks in advance.
*The car is not running in the UK, that's why numbers are higher.
