My Auris Goes Off On Idle
RBUTTIGIEG
HI All,
Maybe someone can shed some light on my problem. I have a 2008 Auris 2.0 D4D TR that has approx 100K Miles. When encountering either roundabouts (thus reducing speed to under 2K RPM) or stuck in traffic therefore on slow movement and slow stops, there are instances where instead of going to idle level of around 800RMP, the engine stalls completely and turns off (even dashboard lights go off).
Any idea what this could be?
Looking forward to some help :)
HI All,
It could be any of a number of things from fairly simple to fairly extensive. If you search in the top panel for Idle Speed you'll find a number of threads, hope it's not as complicated as this guys story:
http://www.toyotaownersclub.com/forums/topic/128042-idle-speed/
Hi all My 2.2 t180 has a strange fault. It first started about 5 months ago when the car was at running temperature it would idle at 1200rpm the air con is off and heater on cold, has i'm well aware this affects the idle speed. Booked car into local dealer and they found that the engine was consuming oil. 2 litres in about 1000 miles. I had a new engine fitted under the extended warranty on the AD series engine.
All seemed fine idle speed was back to 800rpm when at operating temperature and would be 1200 rpm or less when started from cold which is normal. 3000 miles later the operating idle speed starts to creep up to 1200rpm when warm. Another trip to the dealers they play with some connectors idle speed returns to normal, but now the car is down on power no warning lights tho. The dealer keeps the car in for a week talks to toyota technical and replace the ecu that cures idle problem and poor performance.
The car is now perfect again for another 2000 miles when it goes into limp mode, VSC, engine light and traction lights come on. I know this to be common with egr problems. Sure enough AA come out and EGR issue the car is recovered to the dealer has it would not rev past 1300rpm. After they have the car for a week they find the new EGR valve that was fitted when the engine was replaced had jammed closed, they replaced that and kept the car a couple of days to make sure it was ok.
I collocted the car from the garage did about 7 miles and the idle speed was again at 1200rpm. I drove for a further 20 miles the car was fully warmed up and still it was at 1200rpm. Took car back to garage where it has now been for 2 weeks. Toyota technical and the dealer have been swapping all sorts of data but still are unable to find a cause.
So in short When at running temperature the car idles at 1200 rpm if you rev it slightly it drops to 800rpm then slowly picks upto 1200 rpm. There are no air con on, heater is off, or on cold. The car has done 57,0000 miles and full toyota history. I've owned the car for 4 years almost and only use Shell diesel. The car is a 2006 2.2 T180. Any help would be welcomed has the dealer and toyota dont seem to know the cause of the problem.
It turned out to be the 5th injector but you see how complicated it can be. Best of luck to you.
Thanks Tom for your reply. I have taken the car to the mechanic, will hopefully get some results from the OBD test. Hoping that this is a minor issue!
