Gearbox Ratios
mapracing
Hi All
Is there anyway of finding out what the gear ratio and the diff ratio is in the gearboxes of 1999-2005 yaris 1.3 & 1.0
Both my daughters race in Autograss class 1 in there 1.0 yaris
We are building a 1.3 for another class but would like to set up the best ratio's we can,
Also are the 1L gearbox internals the same as the 1.3 ?
Is there any codes on the boxes that would relate to the setup they are running,
Sorry for the questions but woundered if anyone could help
Thanks Paul
To work out the info I need to know where they where built , check the chassis numbers
Starting VN = France
Starting JT = Japan
Thank you for your reply
On the vehicles that i have i will check over the weekend,
On spare gearboxes i have laying around is there a way of telling before removing the internals like the box having a code on?
