Corolla With Manual Windows
sbaksh2
hey guys do you know if the corolla with manual window have the adapter for power windows inside . if i go to the junk yard to get some parts, what do i need to get for it to work ?thanks in advance
no it doesnt, it would be quite a major job to do. You would have to get new door trim, you would need a new window regulator, (this is the part with the motor and lever which pushes the window up and pulls it down. Then you would need all the controls, and wires etc, and you would need to know how to wire it up.... Not an easy task!
thanks, can i just get all the parts from a 99 corolla with automatic window and just hook it up? my car comes with power locks, so i figured i could just plug every thing from 1 car to the next.
yea you could, you might first want to see how everything is connected and wired up in the car with the power windows, before you remove and fit them to your car.
