Toyota Rav 4 1az Engine With Fault Code P1653
I own a Toyota Rav 4 2002 model auto trans with a 1AZ-FSE engine, chassis ACA21..... The check engine light was coming on intermittently but after I took into for reading of the codes it stayed continuously on and the gears now wont shift into OD. The fault code that came up was p1653 (SCV) Where is this valve located and would it be the one responsible for the non shifting of gears into OD.
thanks
  • 4 years later...
I have this exact problem. did you ever find the solution?
  • 3 months later...
Found the solution and in the spirit of not being selfish.. its a bad Vacuum Switch Switching Valve Solenoid Sensor. Part number: 25860-46010
CAR:  Toyota Rav 4 2002 model auto trans with a 1AZ-FSE engine, chassis ACA21
Swapped it and it works like new. Good luck.
 C36B01D5-8188-42DF-98DB-055EF2671253-min.thumb.JPG.a695835c4b10111131ea8b0abffd0adf.JPG
Hi Team,
If the problem was a bad Vacuum switching valve solenoid,why the system has registered a P1653 which is related with suction control valve?
If that is the case,it is a total confusion!
Because the code is a symptom and not the cause
P1653 is a generic obd code and has many meanings
The actual meaning for this code is EGR Vent solenoid
Be aware most obd codes are followed by 2 numbers eg, P1653/01 what are manufacturer specific
  Vent Solenoid Control Circuit Conditions (EGR)
ABS Control Module System Malfunction (AUDI, VOLKSWAGEN)
EGR Vent Solenoid Control Circuit Conditions (BUICK, CADILLAC, CHEVROLET, GMC)
5V Ref Circuit (DODGE)
After-Run Check Error (HYUNDAI)
Engine Control Relay Short To Positive (SAAB)
SCV Circuit Malfunction (TOYOTA
  • 5 months later...
P1653 on Toyota should be  swirl control valve actuator had to sort this code a couple of time
