Find Me An Auris Hybrid!
12 minutes ago, Anthony Poli said:
The laptop says it’s updated, but still can’t see the changes to the map near home.
Sent from my iPhone using Tapatalk
Check version no. Under the SETUP button like i did?
Before
After
Not sure if good idea to show DeviceID? :huh:
Map version look same!
But software is updated(different version)
I guess the map version is: 2016 Feb 1st?
I'll see to morrow when I go for a drive.
When I tried the second time, the update took 29 minutes, yesterday the update for the old map took a minute.
At this rate, u never have time for a wee :laugh:
Are you going to try
or just ask Toyota ?
I prefer Toyota
If they want extra £££ for labour, then i might try myself...
Have u did a search on here on "map update problems?"?
Tried searching but not found anything that applies to our old units
:sad:
I can always get them to check it when the service is due
Good tip from that link: :thumbsup:
I've asked the dealer to let me know the cause of the problem, as I don't want to make this mistake again. My feeling is that there must have been some corrupted data copied to the USB stick by the Touch and Go Toolbox, so my advice to anyone else would be to get two different USB sticks and make two copies of the system using the "copy to USB" option in "General", "System Information" on the unit. That way you will retain the ability to have a second go at downloading from the Toolbox, which might be useful.
And for PiP etc :thumbup:
The Plug in Prius has a third mode. If the charge cable is connected, or the charge connector door is open, and the car is turned on with the brake pedal depressed it appears to turn on in ready mode, as the whole dash lights up (although if you look very carefully it doesn't actually give the "ready" indication). In reality, it isn't in ready mode at all, it's really in an odd form of accessory mode where all the instruments are powered up.
AFTER 30 minutes the car will turn off, even if connected to the charge point, just as if it is in accessory mode.
Shame I don’t have pip, definitely didn’t make that mistake of stopping when the screen went blank.
Sent from my iPad using Tapatalk
Right
Just rung Toyota...
1. SatNav maps £180 (fully installed): 2-3 hrs
Ant!
Your satnav fixed now?
How much u said u paid?:huh:
1 hour ago, Wayne2015 said:
Just rung Toyota...
They are charging for labour as well as the cost of the update.
Going to have another go with a different usb as the other one is a struggle to plug-in.
£110 for the download. 30 min install, but longer to download.
I’d be curious what app version yours is after you have it done
So £70 extra labour for me :ohmy:
Quite a lot for a app install :huh:
I will get my done before Feb...
Quotes for tyres:
1. Winter Yoko £136 (fitted)
2. Summer Nexan £79 / Yoko £152
3. Storage at Toyota
4. Swop tyres £10/tyre
Funny
Thought my Hybrid more efficient in city/A-road than motorway
My full tank last just under 400miles for city/A-road only
Just got back from Bristol and it looks like i got a 440miles range on full tank :clap:
Now normally i get just over 52mpg
But the motorway at 65-70mph i get 58mpg :clapping:
Still waaay below yours, Ant!
But is it my driving in city poor? :crying:
