Oil Changes
steve1967
Hi all new to forum and RAV 4
Looking for some advice on engine and gear oil changes
i have read through haynes manual very confusing :( so hoping to get some help from you guys :)
firstly i have a 2002 3 door rav 4 its petrol manual gearbox
i purchased the car second hand the change from 2 to 3rd gear has i slightly noiser change and more clunky than rest of gears is this normal ?
I would like to do all oil changes from engine and gearboxes ect
from what i can gather from manual i need to do the
1. engine oil and filter
2.rear diff
3.front transfer box
4.front gearbox
is that everything or is there a 5. front diff ?? also to do
also as i live in uk what is the oil i should use for all these changes and does it make any difference to what engine oil was already being used in the car as i dont know what previous owner used
any advise help information would be much appreciated
If you look at the post above yours technical hints and tips you will find an excellent writeup with pictures on changing the gear box oil.
