Hiace 2.5 120 D4d Clogged Intake Manifold
Murkleman
Hi All,
I have had my Hiace for about 2 years now, No problems what so ever then a few weeks ago on approaching or climbing large hills under full load around 80mph, Engine management light comes on & limp mode. I have taken to a diagnostics bloke, fault code was inlet manifold runner control stuck open or something like that, so he cleaned out everything around the inlet manifold but said he couldn't remove the manifold without getting the engine out. Seems a bit stupid and very unlike toyota to me. I have since found an access panel for the rear of the engine under the centre dash console.
So basically has anyone ever had this problem ?
Can you remove the inlet manifold in these vans without removing the entire engine ?
Thanks,
Matt
  • 5 years later...
