60 Plate Estate Oil Maintenance Required Warning
thaiad24
I have a smart start button thing
How do I get rid of the warning message? I assume it's just been a certain amount if miles and not that the oil level is low as the oil light is off?
Cheers in advance
Should be covered in the maintenance section at the back of your owners manual. As far as I remember it is a sequence using the odometer button.
1. Turn ignition key to 'acc' or 'lock' position with the odometer showing
2. while holding the trip reset button turn the ignition key to 'on'
3. After holding the key for 5 seconds the odometer shows all zeros and the light goes out.
Your odometer reading will return to normal afterwards ​
I worked it out
Set to trip A and follow above instructions
