Toyota 2000gt Parts (bellhousing Required)
Hi all,
First time using the site but i'm hoping someone can help me.
I have a Toyota 2000GT, sadly the bellhousing has been damaged recently and needs replacing or repairing (will require a donor bellhousing to repair).
Does anyone know of a good parts suppliers (worldwide or UK) or have any clues as to where I should start looking ? Ideally I need to find a replacement for the bellhousing I have here. I can of course have one made but this isnt ideal.
Are there any vehicles that the Toyota 2000GT bellhousing is used on as a cross reference?
I believe all years of Toyota 2000GT have the same parts fitted.
I look forward to your thoughts.
Many thanks
Will
The DOHC engine was based on the SOHC engine fitted to the Toyota Crown, but as to whether parts such as the bell housing were shared, don't know. The car was such low volume (351 made) that the small batch production was out sourced to Yamaha, rather than being produced by Toyota themselves.
There are literally only 5 registered in the UK - 2 licensed and 3 SORN'd.
Thanks Frosty this is a good start, ill start looking into Crown parts too.
  • 5 years later...
Hi Will. Did you found your part ? Do you still have the 2000GT ?
Luc
