T25 2006 Interior Lamps When Opening Door Not Working
John Andrews
Hello again - now it is dark have noticed that the switch may have fallen apart - how do you get to the switch which says door thanks - need to take off and see If I can repair
cheers
John
the plastic clear part its clipped into the white housing,if you look carefully you will see small prying holes in the plastic, pry them open this will reveal the bulbs I am sure I have seen two bolts or screws around this area when I changed my bulbs to leds
don't know what I did but when taking panel away from roof panel found that switch started to work so popped back - after loosing the two roof screws on floor (note to self to use magnetic screwdrivers next time !) bulbs were ok - thanks for advice
John
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
