Avensis T22 Power Windows Not Working
MartinBz
Hi there!
I have the following problem with my '02 T22: Power Windows are not working, except the driver side. Before the problem occured, I changed pollen filter myself, (behind and right to the throttle pedal). I wonder if I may unplugged something from some kind of socket during the procedure written above. I haven't find anything obviusly unplugged item there though. (Sorry for any kind of errors in my writing).
Looking forward to read some advices and thank you for them.
Martin
The window isolation button on the driver's door hasn't been depressed and locked operation of the other windows??
I agree with Mike. Have you checked the window lock button on the arm rest, close to the drivers window switch.
Easy to knock by accident.
Thank you Gents. I couldn't imagine in my wildest dreams that I could be such a dummy :) I didn't even think about it to check it. (You were right, it was the lock button). Note: The spring and the plastic mechanism which should 'click back' to unlock position after a press is quite worn out, despite the good overall condition of the car, so I had to disassemble it to unlock it.
Martin
