hello,
i have just bought myself an 04 TSport. i have two questions that i need answered:
1 - i have also bought a set of H&R coilovers, are they easy to install or shall i take them to a garage to install?
2 - i want to get a set of 18"s for it, will this effect the drive in any way?
any advice or comments is welcome!
post-141378-0-35250000-1444128186_thumb.
Partly depends what tyres in terms of profile and width one uses.
In order to keep the speedo legal (ie. not under-read and within tolerance as regards over-reading), use a wheel/tyre calculator such as - http://www.alloywheels.com/tyre-calculator.
Generally speaking, the lower the profile tyre used, the harder the ride becomes.
Before making the change, check with your insurer whether they consider the change a modification, and whether there will be any extra premium charged.
thankyou very much, i didnt consider the change it may make to the speedo!! i will contact my insurer aswell just to make sure!
