hi, i recently changed my heater matrix. and it still has cold air. under the drivers side pedals there is a little actuator that if i push up hot air comes on. Now the questions is i think there is a little rod or link that connects to the motor that is missing. Can someone please take a picture from under the pedals where the clutch pedal is and just to the left. I need to see what a working on looks like so i can find the missing part. I will post a pic to show what mine looks like. Thanks it will be much appreciated. i have put a line where i think there should be something connecting.
post-145848-0-20337200-1444264376_thumb.
Looks like you are missing the complete linkage to the bottom motor, compared to my 2006 1.6, though would think the heating systems would be the same ..?
post-95973-0-48970400-1444405430_thumb.jpost-95973-0-51950100-1444405435_thumb.j
thanks, now i have something i can look for.
  • 1 year later...
hi
im looking for the same part
do you have a part num or name for it
thanks
3 hours ago, assafp said:
hi
thanks
Go look for Sam Nadeem of SJ autosport on facebook and he will sort you out.  He is a T Sport breaker.
  • 6 years later...
Hello, I need the same spare part. It is called POM 713 vent regulator
You could follow the link from the last post  -seems to be still active.
If you have access to a 3D printer seems you can buy for £5 the 3D design file to print your own.
AE063700-8930 POM 713 heating guide
https://cults3d.com/en/3d-model/tool/enhanced-and-durable-air-conditioner-replacement-part-for-ae0637008930
