Yaris Mk3 Number Plate Led Housing
Bronxxbull
Anyone know how to fit this? It's the complete housing and the furthest i've got is taking the clear plastic caps off. I get the feeling i need to open the panel on the inside of the boot to unclip the housing. I should have just got LED bulbs rather than the housing, d'oh!
post-150738-0-60936000-1444519892_thumb.
These look as if they replace each light unit so the answer to your question is yes, you do need to take the panel behind the lights off first as you'd probably damage something if you try and get them out without doing it that way...
  • 8 years later...
Sorry to bump such an old thread. The LED ones are so crap.
I have tried 3 "different" ones from different sellers. The original plug doesn't fit well and doesn't click in as it should.
Each one I tested leaked so badly cause of the heavy rains in my area at the time of the test. I swapped back to the original housing and went for some LED bulbs. (much better solution)
