2001 Avensis Estate Rear Wiper Motor
Doodah0784
I was advised that the part number for a rear wiper motor for my 2001 Avensis estate was 85130-05051. I have been sent part number 85130-05050 and told that these are the same. Can anyone please confirm as I do not want to start incurring charges at my garage trying to fit a part that is incorrect? Many thanks.
aslong as from same shape as in t22 facelift and estate it should be fine. Toyota sometimes supersede.
Yes both part numbers should fit and are for the wagon. The part number you were sent is for the earlier version and your number is the later version. There is a cross over so they should fit and work.
Changing the unit would be easy for me as I have removed the motor from my hatchback. You are right to query the part numbers, because of the hassle it can cause.
  • 4 years later...
I have a Toyota Avensis SE estate year 2000 and I’m looking for a rear wiper motor number 85130-05050 or one that will fit?
Where did you get her number 58130-05050 that’s the one I want please let me know who supplied it thank you
