Winter Wheels
Wrench!
Moved to the 'For Sale' section.
Hi John apologies for the late reply I live in Durham which looks a long way from you,however if your interested I could see how much a carrier would charge to get them to you?
hi. I have a 2002/2003 GXR. are your wheels fully compatible
My standard tyre size is 215/70/16 what is the OD or rpm pf your 225/65/17?
thanks
Durham! Durham!! Eee lad I don't even go that far for me 'olidays!!!! :saddam:
Got a tatty and bashed set to see locally but cheers for getting back and very best of luck with the sale
John
Hi Bonjo,
Apologies for the late response see data below should fit fine as stud pattern and et have not changed from your model to mine.
ID Difference 25.4mm
OD Difference 16.9mm
Tyre 2.39% bigger may raise vehicle 0.33inches nothing at all.
