My First Minor Issue Abs/trc, Caution Light Up Due To Bump.
Konrad C
Today I had my first minor issue. Started the car and moved off the drive, being slightly over to the right meant there was a bump, then there was a bep and ABS, TRC/VSC+, and Caution indicators illuminated. Stopped and switched off, restarted all clear.
It seems the bump must have triggered, this as the car was fine for the rest of the day.
Has anybody had a similar experience?
I am also in the process of buying a decent diagnostic reader/scanner. It needs to be universal as I will be using it on other cars. It supposed to support ABS, SRS, steering and EPB as well as OBD2.
Launch X431/CReader CRP129 is top of the list first.
Any ideas will be helpful.
I got the Launch CRP129 and also have the Techstream software. I cleared the fault using the Techstream even though I had US version. It was something to do with the self check not working properly, probably due to the bump when I moved off.
Everything okay since.
