Hi, my rear window defogger is not working. I have checked the 10a and 30a fuses are both OK.
I need to locate the defogger relay exactly. I have found 3 black relays hidden on top of the fuse board behind the glove box by removing the LHS air duct/control.
But which of these black relays is the defogger relay? The light does not come on when I press the deffog switch. And the connections and element on the back window check out all OK.
