Can I Use Biodiesel In Corolla 2012
I have a Corolla 2012 model. Currently, it is running on petrol. I read about biodiesel which work same as petrol and diesel. I want to know can I use biodiesel in my car instead of petrol or not
Well, for the same reasons that you can't use diesel in a petrol car, you also can't use biodiesel in a petrol car.
Biodiesel is still pretty much just diesel!
Petrols don't currently have a biofuel equivalent; There is bioethanol, but this is not really a petrol replacement. You can run with a mix of petrol and bioethanol, but unless it's really really cheap it's not worth it as it has loads of downsides and the only upside is if your car needs high octane fuel, otherwise you get less power from it. AFAIK no petrol engine can run on pure bioethanol tho'.
Just like Cyker said, you can't.
I don't want to start new thread just to say hello, so I'm doing it here! - Hello mates!
I hope we can share our knowledge with each other :)
