Avensis Verso 04 Tailgate Light Unit Replacement
conrod55
I cracked my offside tailgate lens and I've picked up a second hand unit to replace it. Anyone done this before, is it straightforward? Anything to be beware of?
Many thanks.
Avensis Verso T3 D4D, 2004.
on the avensis the rear light lense its held by 3 bolts
here is a diagram of yours.
looking at the back of it there are 4 studs which is where the 4 10mm nuts will go
you may need to remove trim off back door
avensis is held in by philips screws behind small square panels which pull off, then there is about 10 clips holding the trim on
