Head Removal Sequence
Gt4 205
Hi any body no what the sequence is for removing cylinder head bolts on my gtf205:
Hi Tracy, as a general rule in garages it is from the outside in. That means 1 from the far end, then the 2nd one from the other end but the other side (Width wise) then back to the 1st end again loosening the other end bolt then back to the last bolt on the second end and just keep doing this working your way to the centre. I am only initially talking about loosening the bolts, say I full turn at a time and once you have turned them all 1 full turn repeat the sequence, you can remove them fully now that they have all been slackened so the last bolts to come out will be the centre ones.
I have no actual knowledge of GT4's but what I have explained is the general rule and it's the opposite when putting them back in.
A question, why are you removing the cylinder head please, this is not really a job for an inexperienced mechanic.
Regards.
